Old Aug 6, 2015, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Passenger side water leak when using a/c
Old Jul 9, 2006 | 05:28 PM
imnothot02's Avatar
imnothot02
Default Passenger side water leak when using a/c
Im sure the post is on here its a known problem but does anybody have pictures of how they fixed the problem with a elbo etc? I get a puddle of water when i use the ac in the summer on my 2002 dak slt.[&o][8D]
Old Jul 9, 2006 | 07:13 PM
JetNoise's Avatar
JetNoise
Default RE: Passenger side water leak when using a/c
All vehicles do that, as far as I have ever seen.
In addition to blowing cool air, the Air Conditioner also dehumidifies the air in the cab.
This humidity is condensed into water.
This water drips out on to the ground.
It's normal.
Old Jul 9, 2006 | 07:15 PM
imnothot02's Avatar
imnothot02
i mean inide on the floor board under the carpet
Old Jul 9, 2006 | 07:53 PM
vipes's Avatar
vipes
Absolutely normal for any car or truck with air. Watch cars in parking lots anywhere in the summer.
It is not unusual at all - and in fact desirable. Since all air conditioners, including your home unit, acts as a dehumidifier, water will drain. At home, that literally goes into a drain in most cases or out the window with window mounted air. In a car, it just drains underneath the vehicle typically on the passenger side.
Things to watch for? Check to make sure it is really water! Not good if it turns out to be oil, antifreeze or trans fluid Also, if there is no drainage - you might check to make sure the drain plug is not blocked. My Caravan always had a musty odor to it. Found out it was a misinstalled draintube that let the water drain into the passenger footwell and made the carpet all moldy...
Old Jul 9, 2006 | 08:13 PM
superdak05's Avatar
superdak05
up underneath your dash board where the blower motor is there might be a crack in the housing letting the water that suppose to drain outside the vechicle in. its like a house a/c. if the drain plug is plugged or not functioning correctly the water only has one place to go, back where it started from.
Old Jul 9, 2006 | 10:03 PM
imnothot02's Avatar
imnothot02
ive read somwhre that this is a common problem how do you fix the drain tube with a elbo or somthing....
Old Jul 10, 2006 | 01:57 AM
DODGERAM808's Avatar
DODGERAM808
all the ones ive seen with this is a leaking heater core. theres one way to fix it is to find your two heater hoses going into the firewall and run them together with an elbow piece. but your heater will not work now. dependeing on where you live that might not be a big deal
Old Jul 11, 2006 | 10:23 PM
imnothot02's Avatar
imnothot02
so its my heater core that is cracked...?
Old Jul 11, 2006 | 10:55 PM
01Kadota's Avatar
01Kadota
considering it only happens when you use your AC it is most likely a plugged drain hose.
Old Jul 11, 2006 | 10:59 PM
imnothot02's Avatar
imnothot02
okey dokey kinda knew that wondered how to fix it.........
