clogged cat?
2.5 is a little on the large side for a n/a 2.5 liter, even with an intake and full exhaust. Unless you bump compression, increase displacement, or put a radical cam and do some major head work you'll probably lose more bottom end than you'll pick up at the top.
But it's your call, I can only make recommendations.
Thank you for your recommendations.
I did a better performance test today and I gained power across the band.
I spun both 31X10.5s at a stop sign (I couldn't do that when I got it)
But I'll need to get a new clutch before I really open it up.
I don't want to do any major work on this engine except repairs and minor performance.
This engine wil be replaced by a much larger one in 3-4 years.
________
Veronna247
________
Veronna247
