How do i get at my rear speakers??
Old 07-22-2006, 06:58 PM
DODGERAM808's Avatar
DODGERAM808
DODGERAM808 is offline
Default How do i get at my rear speakers??
I remember seeing a post in which somebody detailed how to remove the rear panel and access the rear speakers, but i searched and couldnt find anything. can anybody repeat how to do this? thanks
Old 07-22-2006, 11:26 PM
brbcbrent's Avatar
brbcbrent
brbcbrent is offline
Default RE: How do i get at my rear speakers??
If by ex-cab you mean club cab then I can help:
1. Pry off 2 seat belt hanger covers. Remove one torx t-47 bolt securing each belt hanger
2. Starting at rear of top side panel, pry panel loose and work toward front to release all clips
3. Work seat belt adjustment slide though panel. Remove seat belt from panel and remove top side panel completely.
4. Pry out the bottom side panel starting at the top to release three plastic clips
5. Gently pull panel away to access rear speaker (panel will not come out completely without tearing out most of the rear seat assembly)
hope this helps
Old 07-24-2006, 05:26 PM
DODGERAM808
great thank you very much.
Quick Reply: How do i get at my rear speakers??
