P300 Series Codes Reset?
Old Aug 1, 2006 | 01:04 PM
smartobject's Avatar
smartobject
Default P300 Series Codes Reset?
I'm working on a Cylinder 3 misfire P0303 --- After the prob is corrected, will the code be reset on its own after several miles of driving, or do I need to disconnect the battery to reset?
BTW -- I see alot of past posts talking about Cylinder Misfire codes after a plenum gasket replace, and that's what I just finished, too. Any connection?
I have taken out plug 3 and it was dry and white. Will try a new set of plugs all around, reroute the wires according to the TSB and lastly pull the injector(s) and clean. After that, the only thing I know to check is compression test.
Thank you,
Lee
Old Aug 1, 2006 | 02:51 PM
kurbycar32's Avatar
kurbycar32
Default RE: P300 Series Codes Reset?
i always clear the code before testing so i know if it makes the same code again. if you dont have a scanner you will have to disconnect the battery for like 20 minutes as the computer has a KAM battery
