Few questions...cooling system...
Old Aug 14, 2006 | 12:23 PM
koda360's Avatar
koda360
Default Few questions...cooling system...
I've got a few questions. I have a 2000 Dakota R/T, aprox. 160k miles, runs great. When I first bought the truck, late 2000 with about 2600 miles on it, I never heard the clutch fan run, except maybe a super hot day (90ish) and sitting in traffic. A couple years ago the clutch went out, replaced fan clutch.
Problem, now the fan engages it's self anytime you're sitting still for a few seconds. I know that means it's working ect, ect. I've been around clutch fans along time, but this one seems like it's engaged too often, not that it's a bad thing, it just sounds like a Cesna when you take off....anoying!
My question is, has anyone ever removed the clutch fan totaly, and relied mainly on the electric fan? Is there a way to lower the temp for the sending unit to turn the fan on sooner? I've ran a 180 degree thermostat sence about a week after I bought it. This doesn't seem to effect anything other than the truck runs way cooler, as long as it's moving.
I believe I'm going to buy an aftermarket electric fan, and remove the clutch fan. I was just wondering if you could use the factory elec. fan some how. It seems a little small in diamater to do the job, but I thought I'd ask.
Thanx...
Marcus
Old Aug 15, 2006 | 01:06 AM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: Few questions...cooling system...
Viscous clutches tend to engage after sitting and may stay engaged up to a minute after starting the engine. Drive along at 40 MPH for about 5 minutes then come to a stop and rev the engine, if the fan REALLY roars your viscous fan clutch is bad. In fact, it sounds like it was bad when you installed it. I don't recommend relying on the puny electric fan as a stand alone fan. You need a lot more CFM to keep that RT cool, so a second electric fan will be necessary if you're dumping the belt driven fan.
