01 R/T wont run
Old Aug 17, 2006 | 11:45 AM
coryk4's Avatar
coryk4
Default 01 R/T wont run
ok my cousin has an 01 dakota r/t that will start but wont stay running. runs for about 10 seconds then shuts off. any ideas on what could be the problem.
Old Aug 19, 2006 | 04:41 PM
horatio102's Avatar
horatio102
Default RE: 01 R/T wont run
Sentry key AWOL? Fuel pump on the fritz? clogged fuel filter?
Old Aug 19, 2006 | 10:20 PM
steve05ram360's Avatar
steve05ram360
throttle body needs a good cleaning. take the TB off and remove the IAC valve off the back and clean it up real good, then re-install with a new base gasket (old one will work ok to if you cant get a new one for now) and make sure it's torqued down right.
