electrical ?
Old Aug 18, 2006 | 08:38 PM
rhowe's Avatar
rhowe
Default electrical ?
this is basically an electrical ? If i split the power lines that run to the horns and basically run 4 horns instead of the original 2 off the original power lines, would it be able to power all 4?
i don't honk much except when i convince my little bro to listen for engine noises when i rev it. but i have 2 extra very loud horns that for some reason i want to install under one of the bumbers(mabey the rear to ward off tail gaters). anybody know about this stuff?
Old Aug 18, 2006 | 08:45 PM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: electrical ?
They run off a relay which is fused. As long as you don't exceed the amp rating for the fuse, should work. If it an occasional beep, beep, should be OK. Any long blasts could melt a fuse link.
Old Aug 19, 2006 | 10:19 AM
98Dodger4x4's Avatar
98Dodger4x4
Why do you need 4 anyways?
Old Aug 19, 2006 | 01:09 PM
rhowe's Avatar
rhowe
why not. the other two are insanely loud. cut me off then you'll understand!
Old Aug 19, 2006 | 01:14 PM
98Dodger4x4
I want a air one my stuff to **** people off when they cut me off
Old Aug 20, 2006 | 04:52 PM
fitzer's Avatar
fitzer
You can always tee in another relay to run the other horns
Old Aug 20, 2006 | 06:09 PM
rhowe's Avatar
rhowe
ORIGINAL: fitzer
gd idea. i'll have to find out how to do this.
