Want To Raise the Rear up a Little?
Old Aug 19, 2006 | 03:58 AM
WYOSportPkg03Dakata's Avatar
WYOSportPkg03Dakata
Default Want To Raise the Rear up a Little?
Put on a Camper shell ,Looks Sharp ,But I noticed it sets a Little lower ,Would just like to raise it some and Am Thinking about a Helper Leaf? Do you think it would ride A lot rougher >? Going to be pulling a Boat so think a Helper might be the Way. Someone said to Use the Blocks ??? Replys Please
Old Aug 19, 2006 | 06:25 AM
Dodge_dakota's Avatar
Dodge_dakota
Default RE: Want To Raise the Rear up a Little?
How about a air spring helper
Old Aug 19, 2006 | 10:56 AM
OldDodgeDriver's Avatar
OldDodgeDriver
I use a helper spring and it gets rid of the sag when I pull a trailer BUT it does make the ride harsher. I've been thinking about trying an airbag system myself.
Old Aug 19, 2006 | 11:10 AM
98Dodger4x4's Avatar
98Dodger4x4
Go with the air bags. The ride is alot nicer and very easy to install.
Old Aug 19, 2006 | 11:39 AM
WYOSportPkg03Dakata
Sounds Like A winner , Where do they sell them ?
Old Aug 19, 2006 | 11:41 AM
WYOSportPkg03Dakata
Thanks , Ya I think i'll try the Air Bags Sounds Like what i'm wanting !
Old Aug 20, 2006 | 04:02 AM
WYOSportPkg03Dakata
Thanks 98Dodger For The Info. On Air Bags ,I was Unaware that i Could get Them for My Dakota. Thanks Again! Oh Any Tips On the Best Place to Get them?
Old Aug 20, 2006 | 01:42 PM
Dodge_dakota
stylin concepts theyve got em pretty cheap
Old Aug 20, 2006 | 02:08 PM
BlueDak's Avatar
BlueDak
I use a roadmaster active suspension system. When unloaded you don't know it's there, but it adds about 2K of capacity to you vehicle. Check in an RV magazine for a listing and their website. I have had it for about 2 yrs now, kind of PITA to install, but not too bad. Not sure if they have any installers in Wyo., but depending on how far you are from Colo., I know there are a couple of installers here.
Old Aug 20, 2006 | 10:44 PM
Mikeys's Avatar
Mikeys
Monroe shocks makes a heavy duty shock with a coil spring on the outside of it for the rear of these dakotas. I can load my 4 wheeler up in it and it rides like a dream with little to no sag. They also make what they call "Timberen" which goes on top of the rear axle to stop the bead from going below a certain point. They install where the rubber stops are on the axle.
