Transmission Problem
Old Aug 19, 2006 | 04:59 PM
saunders's Avatar
saunders
Default Transmission Problem
I have a 98 Dakota with the 42 RE transmission. When I come to a stop it will only down shift into 2nd. it will not go into first. The truck set for almost a year. I do have a sevice eng light on so I had it checked out and they said it could be one of several things. I would like to know if anyone else has had this problem. The trans is good they feel it is electrcal. possible solinoid, or govnor.
Old Aug 19, 2006 | 06:22 PM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: Transmission Problem
You should be able to pull the transmission codes. Here's a site with instructions and code explanations:
http://www.fseg.net/Mopar/42re.pdf
