2 engins problem codes - how do I check and fix these?
I'm getting 2 engine codes - what are they/what do they mean and how do I fix them?
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0208 Injector Circuit Malfunction - Cylinder 8
Thanks -
Thanks -
It looks like you have a bad injector on your #8 cylinder and that is causing both the codes. I would propably at least try to pull that one and clean it up if not replace it.
