Rockers or E-Fans
Old Sep 12, 2006 | 01:22 PM
DakotaSport's Avatar
DakotaSport
Default RE: Rockers or E-Fans
cutting/gutting the CAI helps any car, truck or SUV!
Old Sep 12, 2006 | 04:50 PM
kevin505's Avatar
kevin505
cutting/gutting CAI?? do you mean catalytic converter?
Old Sep 12, 2006 | 05:07 PM
DakotaSport
Yes- Catalytic Converter-CAI/CAT.
Old Sep 12, 2006 | 05:08 PM
Chris's Avatar
Chris
ORIGINAL: kevin505
cold air intake. you can modify your existing stock air intake to have colder, denser air delivered to it with minor modification. check prior posts for pictures and instructions of different ways to get colder air into your motor.
Old Sep 12, 2006 | 05:52 PM
jonnymagnum's Avatar
jonnymagnum
ya meangreen did something sweeet to his intake
________
Lovely Wendie99
Old Sep 13, 2006 | 03:42 PM
kevin505's Avatar
kevin505
where do i go to find what he did??
Old Sep 13, 2006 | 04:31 PM
Twiztid's Avatar
Twiztid
He basically removed the front hose off the airbox and ran a hose to the front of the truck by the radiator. That way the hose from the airbox now draws colder air from outisde the engine compartment.
I myself had already ordered the K&N FIPK so I ran the same hose, but instead of to the airbox, the hose just runs to the front of the cone filter to push colder air onto it. Plus it helps keep water out of the intake on those misty mornings.
Some used hose from home depot, some from other sources. I bought a airhose kit from Pepboys as the hose flexed like a drinking straw does, it is flexible, but keeps its form and is not just all flimsy.
Old Sep 15, 2006 | 01:11 AM
kevin505's Avatar
kevin505
back to the cat converter thing. i was on a dakota forum and cutting off the cat is like a very controversal thing. some say its great....others say its not good at all. does it just depend on the vehicle or are people just talking and not knowing anything about what they are suggesting??
Old Sep 15, 2006 | 03:48 AM
horatio102's Avatar
horatio102
Removing the cat will reduce the restriction in the exhaust, but you're also losing your emissions compliance and if pressed can result in you getting a $10k fine, iirc. I went through a State inspection on my 5.0 and they didn't care that it didn't have cats, had 40-series flowmasters (which, btw, are really loud without cats), a non-emissions lumpy *** cam, heads, intake manifold, CAI, MAF, and so on.
Some people say that the OEM cat is a high-flow unit. I don't know about that. It seems that the 3.9, 5.2, and 5.9 ALL have the same 2.5" diameter exhaust though, which is fine for the 3.9 but not so fine for the 5.9, imho. Exhaust is one thing I really want to do to my truck.
