i feel like an idiot
Old Sep 21, 2006 | 10:11 PM
thakota's Avatar
thakota
Default RE: i feel like an idiot
hey virused, you said dont do it while car is hot and not to overtighten, i did both.. whats that mean for my truck =/
Old Sep 21, 2006 | 10:48 PM
f0x672's Avatar
f0x672
i think he said it so you dont
a) burn yourself
b) work on the hot engine cause moetal expands when heated up... so if you take a 'hot' spark plug and put in a 'cold' spark plug... u may cross thread the heads on your engine.... not sure
Old Sep 21, 2006 | 11:53 PM
Chris's Avatar
Chris
i said it because when you are working on a hot block, you can easily strip the threads inside of the block because the metal is softer. also, i have seen people crack aluminum block by overtightening when it is hot. never overtighten or work on the block while it is hot. rule #1.
Old Sep 22, 2006 | 12:48 AM
lil's Avatar
lil
30,000 Miles (48 000 km) or at 24 months
â€* Change engine oil.
â€* Replace engine oil filter.
â€* Replace engine air cleaner element.
â€* Replace spark plugs.
â€* Drain and refill automatic transmission fluid
and change filter (4.7L only).
Old Sep 22, 2006 | 02:21 AM
thakota's Avatar
thakota
NICE!! whats the minimum downtime youd give it to cool down?
Old Sep 22, 2006 | 02:23 AM
horatio102's Avatar
horatio102
The 4.7s don't have aluminum heads, do they?
Old Sep 22, 2006 | 02:17 PM
Chris's Avatar
Chris
thakota: let it cool down until it is at ambient outside temp. dont rush it, go get a 6 pack and tell some stories with your friends. depending on outside temp and engine temp when shut off, it usually takes between 1 1/2-3 hours to cool all the way down. so crack a cold one and chill out!
horatio, that is a great question, and i dont know off of the top of my head. i would assume they are aluminum, but i am really not sure. i will check it out when i get home.
