Transmission will not shift into gears
Old Sep 24, 2006 | 08:45 PM
BJ58's Avatar
BJ58
Default Transmission will not shift into gears
I just changed the fluid and filters in my 2001 Dodge Dakota Quadcab (4.7) ( AutoTrans) and now it will not shift into any gears at all. I've checked the oil level and it's correct. I had just my truck 2 hours prior to changing the oil. Any advie would be very helful. Thanks
Old Sep 24, 2006 | 09:47 PM
Chris's Avatar
Chris
Default RE: Transmission will not shift into gears
check your tranny fluid levels and pay attention on the dip stick to what gear to be in and if it is running or not. i think you have to check the tranny fluid with the truck running and in nuetral. i cant remember off the top of my head.
Old Sep 24, 2006 | 10:17 PM
f0x672's Avatar
f0x672
yea... make sure its on a nice level surface... truck in neutral... running.... parking brake on to check the fluid... if it isnt going into gear... disconnect the battery overnight.... if that doesnt work.. looks like your off to the stealership to have them to reflash the tcm.... when i first changed the fluid in my dakota.... either when i lay the throttle to the floor off the line... wont shift out of first... eh il live...but on turns now... the trans pump doesnt pick up fluid so if i hold the gas.. she will disengage and the engine will spike and then rengage.... rediclous... imma do a trans fluid change soon anyway... i do it every 25000 miles... its a mopar tranny = garbage... but im a huge mopar fan.. so il deal
Old Sep 24, 2006 | 10:31 PM
BJ58's Avatar
BJ58
Thanks, Fluid level is fine and on level ground. I will try disconnecting the battery over night and see.
Old Sep 25, 2006 | 01:13 AM
f0x672's Avatar
f0x672
all that will do is reset the computers... i think normally they reset in like 30 mins.. but i go hardcore with it..
Old Oct 19, 2006 | 01:53 PM
bludak's Avatar
bludak
Did you use the right fluid? The dakota transmission, as well as many other dodge transmisions, use the ATF 4+ fluid as it has special additives to fix shifting issues.
Old Oct 20, 2006 | 03:35 PM
User's Avatar
User
mine has this problem to... when i floor it from a stop it will not shift out of 2nd sometimes and somtimes it does shift. Ive checked all fluids and reset the computer, and it still does it. Honestly im not sure whats going on. I was told it could also be a stretched link.. and it just needs to be tighted.
Old Oct 20, 2006 | 06:08 PM
f0x672's Avatar
f0x672
i have that same exact problem with the full throttle, no shift out of first... either the bands need to be adjusted in the transmission.. or the solenoid valve body has to be replaced... that little valve pack controls the gear shifts on auto transmissions... if they get clogged... thier shot.. dont even waste your time cleaning them
