front lights
Old Oct 6, 2006 | 01:33 AM
skeeter0288's Avatar
skeeter0288
Default front lights
how do you get the front light assemblies out of a 2004dakota? i want to replace them with the crystal clear ones.
Old Oct 6, 2006 | 02:25 AM
skinsfan's Avatar
skinsfan
Default RE: front lights
REMOVAL
LAMP
1. Disconnect and isolate the battery negative cable.
2. Remove the three screws (3) that secure the
inboard and lower mounts of the front lamp unit (1)
to the front fender headlamp bracket (4).
3. Grasp the lamp firmly and pull straight forward to
disengage the ball stud (2) on the back of the
upper outboard corner of the lamp from the plastic
grommet (7) in the fender bracket.
4. Pull the lamp away from the front fender far
enough to access and disconnect the two wire harness
connections (6) from the headlamp bulb and
the front park/turn signal/side marker bulb socket
on the back of the lamp.
5. Remove the front lamp unit from the fender.
BULB - HEADLAMP
CAUTION: Do not contaminate the bulb glass by touching it with your fingers or by allowing it to contact
other oily surfaces. Shortened bulb life will result.
