I'm stupid, help with rear drum brakes on a 97 dak
Old Oct 7, 2006 | 11:26 PM
wizbang360's Avatar
wizbang360
Default I'm stupid, help with rear drum brakes on a 97 dak
have to replace my rear breaks, took one side apart and cant figger out how to get em back together again. Needless to say mech I am not. Is there by chance a walk thru somewhere? I know wishing on a star but not drivable now[sm=dontgetit.gif][sm=hail.gif][sm=headbang.gif][sm=noooo.gif]
just in case it comes up, looked at the other side, and cant figger it out, took it too far apart I belive
Old Oct 8, 2006 | 01:25 AM
01Kadota's Avatar
01Kadota
Default RE: I'm stupid, help with rear drum brakes on a 97 dak
If you only have one side apart just use the other side as a reference.
Old Oct 8, 2006 | 01:37 AM
wizbang360's Avatar
wizbang360
"just in case it comes up, looked at the other side, and cant figger it out, took it too far apart I belive "
one side the adjuster reaches the gear on the lower spreader, but on the other side it does not reach, wish I could give a better description but that is about the best I can do, and one more thing, how do ya get the drum back on once you have replaced the shoes?
Old Oct 9, 2006 | 09:00 PM
f0x672's Avatar
f0x672
im pretty sure it has to be out of adjustment.. like the shoes cannot be spread out... smack the drum on.. and behind the dust shiled there sould be a rubber boot in place to take off and you can adjust by turning that start wheel... thats the genral conception... if the rears are automatic adjusters just get that drum on.. and tires blah blah blah... find a nice open parking lot..... reverse... lay on the gas then slam the rear brakes... that should do the trick.. good luck
Old Oct 10, 2006 | 03:45 PM
Chris's Avatar
Chris
i think you should look at the other drum brake.
Old Oct 15, 2006 | 12:00 PM
01dakota's Avatar
01dakota
There should be an adjuster on the pad spreader. right in the middle of them actually. You need to push that all the way back and then push both pads together as much as possible. Then you should be able to put the drum on over the pads. It may not push in by hand, you may have to use a flat head screw driver and it will push right in.
