kill switch
Old Oct 27, 2006 | 12:15 AM
f0x672's Avatar
f0x672
Default kill switch
im lookin into wiring a toggle kill switch in my truck... problem is.... should i wire it so the starter can be engaged or should i go all out hardcore and wire it to the fuel pump..... fuel pump sounds a bit trcky though doesnt it?.... where as the starter... your just basically running a switch in series of the wire... any opinions would be nice... id rather someone take my stero and my cb then my whole truck.... anyone who touches my dakota is asking to get the snot ebaten outta them
Old Oct 27, 2006 | 12:39 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: kill switch
you should just wire it to the coil. so then you don't get anyspark. thats what I did on my 88 dakota and nobody ever stole it. I always left the keys in it too. they took my stereo once but thats all they could get.
________
Lamborghini Murci?lago History
Old Oct 27, 2006 | 12:51 AM
f0x672's Avatar
f0x672
where exactly should i wire it to the coil?
Old Oct 27, 2006 | 01:32 PM
Erich_121's Avatar
Erich_121
underneeth the ignition coil there are 2 wires, cut it and run a wire to the switch, then back.
Old Oct 28, 2006 | 02:08 AM
asmodeus289's Avatar
asmodeus289
I wired my kill switch to interrupt the starter. I needed something after some POS stole my truck earlier this year.
Old Oct 28, 2006 | 04:42 AM
steve05ram360's Avatar
steve05ram360
I did this on an old chevy I had... there was a jumper put in the wiring harness for a clutch switch (mine was an auto). yanked the jumper and put in a heavy duty switch wiried so it was near my left leg below the seat. push the button, turn the key. it was hard to find unless you knew it was there.
Old Oct 28, 2006 | 04:01 PM
f0x672's Avatar
f0x672
so i guess i can wire it inseries of the ignition switch then?
Old Jun 29, 2012 | 02:53 PM
priceman14's Avatar
priceman14
Glad I found this topic! A family member's van was swiped from a crowded mall parking lot in broad daylight recently.
Don't want my Dakota to be next!
Anyone have any additional $0.02 to add?
Old Jun 29, 2012 | 08:40 PM
ahsnowlover's Avatar
ahsnowlover
My truck came with a alarm system called the silencer that was put in at the dealer and wired into the ctm. It can sence when the door has been opened if it isn't disarmed it kills the ignition system then after 30 seconds it sounds the horn and flashes the light
Old Jun 29, 2012 | 08:53 PM
elecshoc's Avatar
elecshoc
I wired mine using the starter. I used a momentary switch on mine just below my left leg on the seat frame. Some pos went a tore apart the ignition trying to get it going haha...
