new exhaust
Old Oct 27, 2006 | 02:47 AM
MoparOrNoCar00's Avatar
MoparOrNoCar00
Default new exhaust
Alright im going full exhaust and was wondering of a good set of headers. Also would it be worth running a dual setup or jus single. either way im goin to dump it before the axle.
Old Oct 27, 2006 | 04:51 AM
superdak05's Avatar
superdak05
Default RE: new exhaust
gibson makes great headers for the truck. also what are you planning on dueing with the exhaust. is it going around a trailer hitch or not. will you be needing to relocate your spare tire?. i had to go with the 3 inch single cat back because of those very two things. also the single gives the truck more off the line torque, wearas the duels work better in the long running rpms. most people buy the mufflers and go to a exhaust shop and have them bend there own pipes. alot cheaper than buying a kit and installing it yourself.
Old Oct 29, 2006 | 08:24 PM
MoparOrNoCar00
I hadnt planned on running them all the way out the back. i was going to dump it before the axle. Another thing should i run high flow cat or jus cut it?
