NO fire
Old Oct 31, 2006 | 02:08 PM
Dodge_dakota's Avatar
Dodge_dakota
Default NO fire
I just replaced the heads on my 97 dak and I finnaly got it back to gether but theres only one problem I have no spark from the coil wire so please help its a 5.2 318
Old Oct 31, 2006 | 02:18 PM
steve05ram360's Avatar
steve05ram360
Default RE: NO fire
CPS sensor not plugged in... could you have damaged the wiring? it sits back behind the passenger side head.
Old Oct 31, 2006 | 02:31 PM
Dodge_dakota
Default RE: NO fire
thanks for the reply but no good all sensors are pluged in i was thinkin maybe a ground
Old Oct 31, 2006 | 02:34 PM
steve05ram360
Default RE: NO fire
the crank sensor, cam sensor are the 2 responsible for your ignition timing and injector timing. if you have no spark, either your coil is gone, un-plugged, wire pinched & broken, or one of the 2 sensors I mentioned are dead. the crank is responsible for the spark.
Old Oct 31, 2006 | 02:58 PM
Dodge_dakota
Default RE: NO fire
could u tell me where those r located
Old Oct 31, 2006 | 03:19 PM
steve05ram360
Default RE: NO fire
the crank sensor is behind the passenger side head right where the tranny bolts to the motor, the cam sensor is under the distributor cap. here's a pic of where the crank sensor is...
[IMG]local://upfiles/1508/29524B3CB2F54AA39B8DFBEEC9AFFF6F.jpg[/IMG]
Old Oct 31, 2006 | 03:45 PM
Dodge_dakota
Default RE: NO fire
thanks alot the cam sensor was unpluged
Old Oct 31, 2006 | 03:48 PM
steve05ram360
Default RE: NO fire
works now?
