OBD-II Connector Pinout Help
Old Oct 31, 2006 | 06:53 PM
ddavenp's Avatar
ddavenp
Default OBD-II Connector Pinout Help
Could someone with an ~2000 Dakota 4.7 check the wire colors and locations on their ODD-II Connector. The connector is marked with real faint numbers at each corner. (1, 8, 9, & 16) You may need a mirror or push the connector from the metal bracket. I have a new connector but can't find a wiring diagram. I diagram from someone that has access would be great also. Thanks
