broken bleeder nut
First I have a 97 Dakota with 3.9 and 4X4. Recently the main metal break line going to the rear tires blew. After I replaced about 11' of break line I tried to bleed the break system. I first tried rear passenger side; I noticed a little rust so I soaked it in Liquid Wrench for about 20 min. When I tried to loosen the bleeder nut, it broke off. After cussing for about 20 min I soaked the other side in liquid wrench for about 24 hours, soaking it now and then. The next day I tried to loosen that nut and it too broke off. There isn’t enough room to drill the remainder out. What do I have to remove to get the remainder of the nuts out? The seal part of the nut is still intact, is there another way of bleeding the lines? BTW the nut I tried to remove is just above the break line leading into the drum break.
