Weird noise
Old Nov 9, 2006 | 02:06 AM
mnbf's Avatar
mnbf
Default Weird noise
ok i have a 1997 dakota sport 5.2 L and when i put it in 4 hi or 4 lo and go to drive there is a lound clunking soudn that is continous when im on the gas hard.. if i drive slowly it doesnt do it as much.. it does it more with the wheel turned.... this is a 5 speed truck.... the sound is really loud and i was wondering if it would be chain slip in the transfercase or if anyone had any other idea to what it could be... thanks
Old Nov 9, 2006 | 02:52 AM
f0x672's Avatar
f0x672
Default RE: Weird noise
does your truck happen to hop around?... is it autp or manual?
f0x672's Avatar
f0x672
does your truck happen to hop around?... is it auto or manual?
Old Nov 9, 2006 | 11:33 AM
mnbf's Avatar
mnbf
the shifter hops around and its an 5 speed
Old Nov 9, 2006 | 09:33 PM
mnbf's Avatar
mnbf
1 more thing to add is that the truck runs and sounds fine in 2 wd
Old Nov 10, 2006 | 02:12 AM
kurbycar32's Avatar
kurbycar32
when in 4 wheel drive on any truck you should avoid turning the wheels very far, you get hydraulic lock or something in the power steering system. im not sure if thats the right name for it but essentially your power steering has to fight the 4x4 system when the wheels are turned all the way in either direction. it can really bog down your motor and cause noises/jumping.
Old Nov 10, 2006 | 02:33 AM
mnbf's Avatar
mnbf
ORIGINAL: kurbycar32
thanks.... but that has nothin to do with my problem lol
Old Nov 10, 2006 | 02:36 AM
kurbycar32's Avatar
kurbycar32
sorry, i picked up the the 4 wheel drive turning and clunking..
Old Nov 10, 2006 | 04:50 AM
DODGERAM808's Avatar
DODGERAM808
if your shifter is jumping up and down that is a good indicatation that the tranny mounts are bad.
Old Nov 10, 2006 | 11:38 PM
mnbf's Avatar
mnbf
ORIGINAL: DODGERAM808
yea im pretty sure it is bad but ive called every where looking for a new one but no one has a listing for a 97 dakota v8 5 speed 4x4... also the sound kins sound like somthing it outta round cause it will bang stop bang stop bang stop.... buit when im going faster in my truck it seems to be fine... is there anyway it could be the chain in the transfer case or is that somthng that just either works or doesnt work? im new to the whole 4x4 thing so im not sure thanks
