Clutch Fan? HELP PLEASE
Old Nov 28, 2006 | 10:25 PM
bucktweet's Avatar
bucktweet
Default RE: Clutch Fan? HELP PLEASE
at lower rpms it is a buzzing noise but when you get in to the higher rpm's it gets higher pitched like a whistle, could dirty, or low transmission fluid cause this?
Old Nov 28, 2006 | 10:54 PM
jonnymagnum's Avatar
jonnymagnum
will it make the noise when it's in gear and out of gear. try driving it and when you hear the noise, take it out of gear and see if it stops.
________
How To Clean Vapir No2
Old Nov 28, 2006 | 11:04 PM
bucktweet's Avatar
bucktweet
No it only makes the noise if it is in gear and you are pressing the gas, it doesnt matter how hard you are pressing the gas it always does it, and it doesnt stop when it warms up.
Old Nov 28, 2006 | 11:09 PM
jonnymagnum
try doing a tranny flush on it. thats where they take all the fluid out and put all new fluid back in. it's around $100 to do it but it should solve your problem. and maybe get them to take a look at your tranny while they have the pan off.[:@]
________
Volcano classic easy valve
Old Dec 1, 2006 | 01:07 AM
bucktweet's Avatar
bucktweet
Well i put on a new trans mount, and had my transmission and rear diff fluid changed and it still make the noise i have no clue, guess i will just have to live with it.
Old Dec 1, 2006 | 01:34 AM
klings designs's Avatar
klings designs
I have the same problem, only when it is cold out.. It makes an airplane whistling noise? If that makes sense... Only when it is in gear, and you are pressing the gas.. if it starts to whistle and you let go of the gas it will stop whistling? its got to be the most annoying thing...I have automatic.. Do you got stick?
Old Dec 1, 2006 | 02:31 AM
bucktweet's Avatar
bucktweet
yea that is the same thing mine does, i have a stick, but mine does it every single time i drive it doesnt matter if it is cold or warm, i was stuck in water up to my doors and ever since that it has made that noise, i am out of idea's, it is very annoying tho
Old Dec 1, 2006 | 02:38 AM
dodgedakota98luver's Avatar
dodgedakota98luver
well if you got it stuck in water up to your doors then you could have got water somewhere in your drivetrain and then it wouldnt be properly lubricated and could mess something up. have your front axel and rear end checked out *just a thought*
Old Dec 2, 2006 | 12:41 AM
klings designs
HEY HAS ANYONE CHECKED TO SEE IF THEY GOT THEIR CATALYTIC CONVERTERS CHECKED. I READ THAT THEY MAKE A WHISILING NOISE WHEN THEY ARE CLOGGED?
Old Dec 2, 2006 | 05:44 AM
dodgedakota98luver
you catalatic converter makes a high pitch wistle in neutral if you rev it up if you only get it when your in gear its not your cat plus you can only hear the cat sound outside
