Nitrous Setup
Old Nov 27, 2006 | 04:51 AM
kurbycar32's Avatar
kurbycar32
Default RE: Nitrous Setup
ORIGINAL: dodgedakota98luver
i just love the look on smart *** kids faces with sports cars when you outrun them in a big truck lol i just like to be different
*this is really off topic but* KurbyCar i see that you have an underdrive pully on your truck and you have a big amp and subs i'm running a 760 watt pioneer amp with 2 10 inch subs and my headlights dim every time the bass hits. Do you have that problem? and does that underdrive pulley make it worse?
as you can see i have a pair of amps but not near the wattage that you run. i dont have any problems but i do notice that if i am stopped at a light with the blower on full blast AND the stereo cranked that the voltage hovers around 12v instead of 14v. it may have done this stock though, i installed the under drive like a month after i got the truck. with your giant amp it would probably be a good idea to get a huge capacitor in line with that system to level out the load a bit.
edit: i also only have the subs turned up to like 20% on the amp, thats where it sounds best listening to rock.
Old Nov 27, 2006 | 02:50 PM
dodgedakota98luver's Avatar
dodgedakota98luver
much appreciated thanx for the tip
Old Nov 28, 2006 | 07:46 AM
EvilZombieZ's Avatar
EvilZombieZ
I would not use nitrous on a stock engine unless you have the money to replace in. Hell in fact even if you have a modified engine I wouldnt recommend it.
Old Nov 28, 2006 | 05:52 PM
DEMONDAKOTA02's Avatar
DEMONDAKOTA02
i agree with Evilzombiez running Nitros is real risk. i have plenty of speed with the parts i have on my truck the only problem the way that i went is a whole lot more expensive and literally broke me to do it. But i am glad i did it and not just went with the cheap and fast way of nit. Well good luck which ever way you may go.
Old Nov 28, 2006 | 06:35 PM
Chris's Avatar
Chris
if you take your time with a NOS setup, get the correct computer controler and know when to use NOS, it can be an inexpensive and reliable way to dramitically/temporarily gain horsepower. the problem with nitrous is that people do not know how to use it correctly. most people are using either too much or they make an idiot mistake like popping the bottle open at idle. like i said before, if you know what you are doing, nitrous can be a great advantage. if you dont know what you are doing, stay the hell away.
just my $.02
also, if you do decide to run nitrous, always run the correct amounts for your particular engine. it is always safer to run less nitrous than too much.
Old Nov 29, 2006 | 01:51 AM
dodgedakota98luver
why exactly does your engine need to be at a minimum of 3,000 RPM when you flip the NOS? because thats what the recomendations say for a kit i was looking at. Also how long does a NOS burst usually last? how many would you get out of a 10 LB bottle and how much does it cost to refill?
Old Nov 29, 2006 | 07:06 AM
WhiteR/T5.9's Avatar
WhiteR/T5.9
How long a 10lb bottle lasts depends on the shot size you're using. When I ran a 35 shot on a 10lb bottle on my Talon, it lasted a fairly long time. It was set up to where at full throttle the throttle would push a button to inject the nitrous as long as it was activated by switch inside the car. Thanks for everyones advice.
Old Nov 30, 2006 | 01:16 AM
dodgedakota98luver
are the dry nitrous systems more dangerous than wet ones cause my dad seems to think they are i just want to get a little insite from some other ppl. he knows what he's talking about most of the time but sometimes he really doesnt. like when it comes to the whole backpressure argument velocity good backpressure bad he just wont believe it
Old Nov 30, 2006 | 01:22 AM
batman13's Avatar
batman13
As long as you know what you're doing,( saw a civic engine acually dismantle itself when some idiot hit the switch funny ****) It should be safe to run 100 shot
i'd go with any safety measures to get more life out of the engine.
Be good
________
Colorado Medical Marijuana Dispensaries
Old Nov 30, 2006 | 01:39 AM
dodgedakota98luver
well i'm wanting to find a dakota R/T reg cab and put the sniper body kit on it and build it up for drag racing legaly at a drag strip so i figured i'd get some info on this stuff i dont plan on putting it on my 98 so is wet or dry the better way to go?
