Battery gauge
Old Nov 28, 2006 | 12:27 AM
bs2723's Avatar
bs2723
Default Battery gauge
I have a 2000 Dodge Dakota and when I crank it up it seems to run fine. After about five minutes the volt gauge (battery) goes all the way
down, and the check gauges light comes on. It also threw the belt off. I thought it was the alternator so I replaced it. The truck is still doing the same thing. I hope some one can help.
Old Nov 28, 2006 | 02:06 AM
rhowe's Avatar
rhowe
Default RE: Battery gauge
try checking the belt tensioner
Old Nov 28, 2006 | 01:04 PM
kjun's Avatar
kjun
If the belt came off definitely look at the tensioner. The belt wasn't tight enough to turn the alternator thus the low charge. Also if tensioner is bad and not fixed, your water pump won't turn correctly (overheat possiblity) and your steering will get tight without the P/S pump turning correctly.
