Super Charger
Hey guys i have a 97 v8 5.2l and i want to run a super charger in it (novi 2000 and a paxton kit) what parts would i need to be able to run this safley at 14 psi? and where can i find these parts and how much we talkin?
thanks
thanks
get ready to spend a little money! you will most likely need a head rebuild and possibly some new connecting rods, not to mention new seals on everything. if i were you, i would just run it at around 8 psi and keep your motor stock.
just my $.02
just my $.02
you should also contact the manufacture of the supercharger and ask what their suggestion is on what compression you should be running. i'm only speaking from experience with turbos, to run that much boost you are going to need to lower you compression ratio. I would take the advice of running about 8 psi of boost though, 14 is just insane. be prepared to replace your rear-end and driveshaft
New forged pistons, connecting rods, nitride coated valves to handle the added heat, probally a bigger radiator to handle the extra heat. Probally bigger head, main, and rod studs, MLS headgasket. Basically a complete rebuild, not to mention a new camshaft, some sort of fuel and timing management. This is not something you can just slap on and go with. And don't call me a noob, I own a 90 Eclipse Turbo, and I know what it takes to make added power with forced induction.
If you were to actually do this, I'd probally go with a centrifugal type supercharger, and a charge cooler (intercooler).
well i guess from what im getting here ill proably get a super charger now and run it at like 7 for now and in the next few months ima go ahead and install everything else cause i was planning on buys those parts either way
