32's
Old Dec 1, 2006 | 02:03 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Default 32's
i've got 31x10.50's on my truck how hard would it be to put 32x11.50's on it?
Old Dec 1, 2006 | 04:19 PM
Chris's Avatar
Chris
Default RE: 32's
You will not be able to fit them without some serious cutting if you do not have a lift kit.
Old Dec 1, 2006 | 05:03 PM
V8Boss's Avatar
V8Boss
Default RE: 32's
I'm not sure if the Sport you have has the same clearance as my SLT but I have 32x11.50s with no cutting, no rubbing on turns...perfect fit. Check out the pics on my gallery. They look great.
Old Dec 2, 2006 | 05:34 AM
dodgedakota98luver
Default RE: 32's
my truck is 4 wheel drive virused they sit up higher from the factory. The only place i'm worried about is the frame on tight corners. Would wheel spacers help?
Old Dec 2, 2006 | 10:59 AM
V8Boss's Avatar
V8Boss
Default RE: 32's
If you have the same clearnance as me, like I said, I dont rub at all....even on sharp turns. It comes close but its got about 1/2" to 1" of clearance on the front spacing when I am turning and plenty on the back spacing.
Old Dec 2, 2006 | 12:44 PM
batman13's Avatar
batman13
Default RE: 32's
shouldn't be a problem, i don't have the 4x4 but the 32's should fit
our dak's have HUGE wheelwells
The F250 at work rubs with the STOCK tires[&:]
________
HotBlondyBabe
Old Dec 2, 2006 | 06:04 PM
racin_40's Avatar
racin_40
Default RE: 32's
32's will fit fine ,the only problem i have is i am running mopar running boards and they rub where the boards mount to the fender flares not biggy
i have noticed they do rub the inner fender when turnt to the lock position
if you lived close ot me i would just let you try 1 and see
these were new when i bought the truck and honestly i would sooner have the 31's on it and keep it stock just preference i guess
