no headlights
Old Dec 8, 2006 | 01:44 AM
nitrobrian's Avatar
nitrobrian
Default no headlights
2000 with no headlights.Power at all three wires at the light.The high beams and park lamps work fine.So do the fogs.Fuses,bulbs and switch are new.
Old Dec 8, 2006 | 01:59 AM
phatjohn's Avatar
phatjohn
Default RE: no headlights
Is it in both lights or just one? If it's in just one, the I would say that eventhough the bulb is new it may be bad. Do you have a way to test the new bulbs in a different Dak?
Old Dec 8, 2006 | 02:43 AM
horatio102's Avatar
horatio102
power at all three??
download and read the section in the manual I know it's a 2001 manual (look in the forum for it). Sounds like either the wiring between the multi-function switch and the headlight bulb, the multifunction switch itself, or your central timer module (??).
Get a multimeter and start testing stuff against the wiring diagrams.
Old Dec 8, 2006 | 05:05 PM
Chris's Avatar
Chris
God I hate electrical problems. [:@]
Old Dec 11, 2006 | 04:13 PM
Erich_121's Avatar
Erich_121
ok there shouldnt be power at all 3. IF there is how is the current going to go from positive to negative if they are all positive. You should have 2 wires at 12V, one for each beam and a ground. Sounds like you have a grounding issue.
Old Dec 11, 2006 | 04:14 PM
Erich_121's Avatar
Erich_121
remember only one at a time will be 12V with the headlight switch on.
