HEATER PROBLEMS
Old Dec 9, 2006 | 01:05 PM
gerry98's Avatar
gerry98
Default HEATER PROBLEMS
im having heater problems with my 98 dakota 5.2l. when im drivng there is good heat, but when i come to a light or just idling it blows just barely warm air . soon as i take off its ok. what do you guys think it is
Old Dec 9, 2006 | 01:41 PM
98Dodger4x4's Avatar
98Dodger4x4
Default RE: HEATER PROBLEMS
weild I heard of that when the AC is on but never the heat. I will see what mine does today when I drive home and repost.
Old Dec 9, 2006 | 01:46 PM
gerry98's Avatar
gerry98
thanks
Old Dec 11, 2006 | 02:06 PM
Chris's Avatar
Chris
Gerry, it appears that it is time to give your heater core a flush. Follow the link below and let us know how it works for ya!
https://dodgeforum.com/m_640588/tm.htm
Old Dec 14, 2006 | 04:02 AM
labradorian70's Avatar
labradorian70
It could be that your thermostat is sticking and not regulating like it should, this will cause warm air in your heater instead of hot air. When you speed up from stop the engine is working harder and heats up again.
Just a thought
Good luck
Old Dec 14, 2006 | 05:31 PM
hotmilkman's Avatar
hotmilkman
I just experienced the same exact problem. You might just be low on coolant. When the coolant gets warm it heats up the heater core causing warm air to blow into the cab. Watch your temp guage when you come to a stop, if it starts to go up then definately check the coolant. I just drained what was left in mine added 50/50 coolant/water to it and it works fine. If that's not it then it could most likely be a thermostat issue.
Mike
