heater problems
Old Dec 10, 2006 | 10:43 PM
lumberjack041906's Avatar
lumberjack041906
Default heater problems
Having heater problems with a 2004 dakota 4x4 3.7L, heater fan quit won't come on at all.Also looking for a repair manual for the same truck.
Old Dec 11, 2006 | 12:04 AM
superdak05's Avatar
superdak05
Default RE: heater problems
first off look for the ppower wire. tap into an aux. feed and see if it works, if not its the fan, if it does than you blew a fuse or a fuseable link. switch might have shortened out also. check yo see if the cig, lighter works. i believe they are on the same fuse
Old Dec 11, 2006 | 12:36 AM
Chris's Avatar
Chris
Superdak has you on the right track. Also, you can download the manual the lil posted a while back.
Old Dec 11, 2006 | 07:54 PM
lumberjack041906
Thanks
