Difference between motors?
The motor itself? Zip, zilch, zero differences.
The ECU is tuned a little differently and it has a little different muffler, that's about the extent of the differences between an R/T and non-R/T, and what makes up the few hp difference.
if you are going to rebuild the 360, punch it out to a 408 and you will see quite a big difference in power, go to www.krcperformance.com and see there dyno shts, compared to the motors. also there is some much avail. for the 360 in performance parts
ORIGINAL: horatio102
Really...I thought they had a diff cam for one.
The 408 is made by stroking it right? That would be sweet.
ORIGINAL: Twiztid
Nope, 318 and 360's all used the same cam in the recent past (perhaps from the early/mid 90's when the Magnums took over.)
There's only a 5hp and 10lb-ft difference - muffler and ECU tuning tweaks only. If it had a different cam + muffler and ECU tweaks I would HOPE they'd get much better numbers.
I've looked up the parts in the OEM catalog (www.dodgeparts.com), go ahead and try to find a different cam.
And check the valve timing specs - there's one set of specs under 5.9 liter engine. The R/T's just aren't that special (no offense guys, I wanted one until I got my qc and got basically an R/T 4x4).
408 is made by boring a 360 out .030" as well as using a 4" stroker crank. Hughes has a 426 kit for the 360 as well, using a 4.166" crank, or some such thing. Without boring to clean up the cyls a 360 with the 4" crank is 402 cid. .060" overbore results in a 414, and .080" equals a 418, although that leaves some thin cylinder walls and when it needs a rebuild, the block is basically done so it's not a wise choice.
Trending Topics
Yeah I saw other configs with higher HP, turbo and supercharged, hell one had 700+hp 408.
I don't want it to be so extreme I have motor issues, something powerful yet functional. Plus I am all about pulling and mountain trail off-roading, so I would rather have a low-rpm torquey motor than a high-rpm racer. If I needed an extra jolt I could throw a 150 shot of nitrous on it and get an extra 100hp/ft-lbs when needed
That site had alot of different configs to think about though.
