heater core flush instructions Dakota by Virused
Old Nov 18, 2014 | 03:20 PM
  #51
chief2783's Avatar
chief2783
Default hc flush
Thanks for the help. I would be interested in more tutorials if this is a regular thing u do
Old Nov 19, 2014 | 12:01 PM
  #52
Dodgevity's Avatar
Dodgevity
Originally Posted by 00DakDan
Turning the **** to high does nothing. Our trucks don't have a heater control valve.
Dan, if there is no heater valve, how is the flow of hot coolant stopped through the heater core, when using AC or cool air? Just curious.
Old Nov 19, 2014 | 02:48 PM
  #53
00DakDan's Avatar
00DakDan
Section Moderator
It isn't stopped. Coolant always flows.
There is a blend door in the plenum. It directs air over the heater core when you want heat.
Old Nov 19, 2014 | 02:49 PM
  #54
RalphP's Avatar
RalphP
Dodgevity - There is one, but it's an on/off valve, not a more/less variable valve. And not all of the trucks have that, I understand!
RwP
Old Nov 19, 2014 | 03:18 PM
  #55
00DakDan's Avatar
00DakDan
Section Moderator
RwP
Not in a 2nd gen Dakota.
Old Nov 20, 2014 | 09:49 AM
  #56
Dodgevity's Avatar
Dodgevity
Got it. Guess the system does a pretty good job of keeping the hot air at bay when you don't want heat then.
