v6 dakota tranny
Old Dec 13, 2006 | 12:07 PM
Bluedakota2000's Avatar
Bluedakota2000
Default v6 dakota tranny
Hi, I just bought a 2000 dakota v6 auto. When its cold the truck has trouble shifting from 2nd to 3rd and you have to kind of let off the gas for it to shift because it will rev really high. Once the truck is up to temp. it shifts normally. Tranny fluid is still red and is not low but may be a little bit high. Not sure what the previous owner put in for fluid but im just wondering if it works fine once warmed up if it could be something else. Just want to get some opinions before I start changing things (fluids, etc.)
Any helps is appreciated
Also I'll add that I am mechanically inclined to work on my truck, I've been swapping engines and building turbocharged civics for years, just this is my daily driver.
Thanks
Old Dec 13, 2006 | 01:23 PM
Erich_121's Avatar
Erich_121
Default RE: v6 dakota tranny
My truck does the same thing. I think its normal.
Old Dec 13, 2006 | 09:00 PM
Bluedakota2000
So is everyones truck doing this? I looked in my owners manual and in the maintenance schedule for miles on the truck there seemed to be a few tranny oil changes which also said band adjustment. Maybe we need to get the bands adjusted? I checked the cable to the tranny from the throttle body, seemed okay, doesnt seem to have much tension or resistance coming from the tranny though. Anyone know?
Old Dec 15, 2006 | 02:23 PM
Erich_121's Avatar
Erich_121
now that i look back at this i realize that mine is a 5 speed. Now i think its not normal. I would try changing the tranny fluid and see if that helps. I do know that the bands need to be adjusted every now and then.
Old Dec 15, 2006 | 05:01 PM
demarco0129's Avatar
demarco0129
eric_121,
mine is a 5 sp. as well, and when its cold outside it doesnt let me shift into second and its very very stiff switching gears in general. It usually gets better once it warms up...is this what you are experiencing? Im just trying to make sure that there is nothing wrong with mine for doing this. Also, can you help me locate where to check transmission fluid?
Old Dec 25, 2006 | 02:21 AM
F22Raptorman's Avatar
F22Raptorman
I have the same problem, my mechanic said the shift points were off, so I took it to the dealership and there was an update from mopar to correct this. It is better since the updated my computer but it's still there so it looks like were stuck with this one.
