changing oil suggestions
Old Dec 14, 2006 | 03:51 PM
ccm182's Avatar
ccm182
Default changing oil suggestions
i have a i just changed my oil under my 2000 dakota and i noticed that they did a poor job of leaving room forthe oil to pour straight out so on and so forth. after getting oil all over me, the truck, and the ground. i figured i would come here and ask if there is any suggestions on how to make the oil drain more simple with less of a mess or will i just have to rig something up to make it less of a mess? thanks
Old Dec 14, 2006 | 03:53 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: changing oil suggestions
just get a bigger drain pan
________
Montana medical marijuana
Old Dec 14, 2006 | 03:54 PM
Chris's Avatar
Chris
I am assuming that you are referring to the oil filter swap. You can simply hold a syphon connected to a hose to be able to aim the oil into the oil pan.
Old Dec 14, 2006 | 04:18 PM
ccm182's Avatar
ccm182
aaaaahhhhh i shall try that the next time i change my oil. and i was referring to the complete oil change. draining the oil and the oil filter are both messy as hell to change. i am going to try different things and i will post them up if i find a reall clean way to change them both.
