cam?
i'm wanting to put a cam in my 5.2 also i'm wanting a lot of horsepower but i dont really want my low end torque to suffer cause personally i'd rather have torque than horses in a truck. anyone heard of rhodes lifters? they are supposed to save your torque and economy and idle quality when you put a big cam in
i have a crane throttle body spacer and stage 2 jet chip and i dont care what anybody says i def. felt more low end power with the those additions!! but any way i just want to get more power out if my truck.
ORIGINAL: shaun826
For the money there are alotof other mods to due.
Trending Topics
I myself would still do intake manifold, 50mm TBand rocker arms first.
But that leads us back to horatio's questions, what do you want your truck to do? I am not the most knowledgable with cams, but from what I see, cams can add alot of horsepower, but will generally rob from torque at the same time. Thats why I say there are other things to go for.
check out www.krcperformance.net and click the dyno page. You can kinda gather how diff parts will effect your motor.
I have a small cam lift on mine, but it was in it before i bought the truck. So i don’t know how much HP is added.
I know a stock 5.9L R/T is about 250 at crank so about 180 on ground? I have heads, rockers, cam, ram air, flow pro exhaust with dump, headers, bigger fuel injectors, M-1 Intake manifold... and i had my truck dynod with no tune, and i was getting 267hp to the ground and 340tq on the ground, was getting the most power around 3k rpm.
Im about to add a 53mm TB, msd ignition, andgetit tuned, with a new comp flashand im going to re-dyno the truck and see where that gets me.
I know these trucks have a lot of tq. Torque is what’s going to beat them off the line when you get a good launch. They have so much torque you need wider tires lol.. i use to burn forever and would have to catch up when i hit 2nd... get some wider tires and watch there mouth drop!
