question?
Old Dec 27, 2006 | 02:43 PM
Abomb36m's Avatar
Abomb36m
Default question?
180 thermostat? whats it do, i bought one and a water temp gauge. will it make any type of difference?
Old Dec 27, 2006 | 03:02 PM
Chris's Avatar
Chris
Default RE: question?
A 180 degree thermostat will make your engine run cooler because it allows coolant to flow through the motor when the motor reaches a temp. of 180 degrees, as upposed to stock which is 195 iirc. The temp guage will just give you a reading on what the temp of the coolant is at the location where you mount the sensor.
Old Dec 27, 2006 | 03:08 PM
Abomb36m's Avatar
Abomb36m
thanks
Old Dec 27, 2006 | 03:30 PM
horatio102's Avatar
horatio102
The reason for the 180 t-stat is that a cooler engine will resist detonation better, meaning you can run more timing and pick up power and fuel efficiency. Dodge uses 195 t-stats from the factory because a hotter running engine will burn off emissions more completely, making it better for the sniffer test.
