Loud Radiator Fan
Old Dec 27, 2006 | 11:39 PM
chefpaulevans's Avatar
chefpaulevans
Default Loud Radiator Fan
My '01 4.7 has a loud fan right now. It seems like the fan is stuck in the warm-up mode, like when you first start the engine. Is the fan clutch bad? How do I go about replaceing it?
Old Dec 28, 2006 | 01:26 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: Loud Radiator Fan
it sounds like the fan clutch is stuck. one way to tell is to just try and spin the fan. there should be a bit of tension on it. but I think you will have to buy the whole fan to replace it. I dont know if you can just buy the clutch buy its self or not.
Old Dec 28, 2006 | 02:48 AM
chefpaulevans
Thanks for your help.
Old Dec 28, 2006 | 08:42 PM
Chris's Avatar
Chris
If you are going to have to replace the clutch, look to see how much it would be to buy an electric setup.
Just my $.02
Old Dec 29, 2006 | 08:46 PM
lone_wolfin's Avatar
lone_wolfin
I have an 02 Dakota 4x4 with the 4.7 as well.
It was in a wreck (clutch fan is messed up).
Ijust want to run an electric fan on this (no clutch fan).....
I have the big nut cut off the clutch fan assy
in case I would need toinstall it on the water pump pulley.
Is there anything special i have to do when doing this?
thanks in advance
Old Dec 29, 2006 | 09:01 PM
jonnymagnum
hooking up an electric fan is fairly easy. you can buy the kits to convert it but there pretty expensive. I was thinking on putting an electric fan on mine over the winter. you can just hook it up to a toggle switch and then you can turn it on when ever you want. I'm not sure how you would hook it up to a sensor to turn it on automatically though. and mounting it is pretty easy. just get 2 pieces of flat bar and run then across the rad. then bolt the fan to it and your set.
Old Dec 30, 2006 | 04:23 PM
lone_wolfin
Flex a lite doesn't have a set up for us yet, but they did tell me to run
the 290 (i think....)...
this fan is for the ford mustang, has a shroud, pulls
twice as much air (and if it can keep a 5.0 Mustang cool, then i would think
it would keep our 4.7 cool).......
only bad thing is.............it cost over $400.....ouch
I am going to the boneyard and gettinga fan assy off of a TransAm or Mustang ($50...plus you can get replacement motors seperately cheaply).
Then you can get a coolant fan sensor from GM that will close its contacts at
a certain coolanttemp...with that, you can control a relay that will supply power to the fan......turning on the A/C will still activate it as well.....
