damaged throttle body
Old Dec 29, 2006 | 01:40 AM
BeachCruiser's Avatar
BeachCruiser
Default damaged throttle body
cracked the flange around the TB on my 97 3.9L today as i was tightening down the last bolt after putting on my new TB spacer(only torqued the damn thing to 20lbs). I could just JB weld it, only the flange is cracked, not all the way through the TB, but I figured i might as well try to find a junkyard V8 TB if i can. Could someone fill me in with all the info on doing this. Will both the 5.2 and 5.9 TB work? Any modifications need to be done, or do i just plug everything back in the same way? Can't think of any other questions, let me know if you think of anything else. thanks
Old Dec 29, 2006 | 01:46 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: damaged throttle body
well it serves you right for trying to put on a throttle body spacer
I would take the tb spacer back and go to a junkyard and find a V8 tb. the 5.2 and 5.9 are the same. I think all you have to do for this mod is, a new throttle cable and bore out the intake holes to match the V8 tb.
Old Dec 29, 2006 | 02:32 AM
lil's Avatar
lil
hehe cracked or not it is nothing more than a paperweight.....like jonny says get the "throttle body" off a 5.2/5.9L and it makes a nice diff add a cold air intake and you will add 15-20HP between the two mods.....not to many mods for the 3.9L better than that
Old Dec 29, 2006 | 06:33 AM
horatio102's Avatar
horatio102
20 ft-lbs is quite a bit for small bolts going into aluminum. Junk the TB spacer and get a new TB
Old Dec 29, 2006 | 01:48 PM
Ethica19's Avatar
Ethica19
I've got the TB I took off my 3.9 when I put in my V8 TB, you looking for one of those?
