about to do a lot of maintainence, any tips?
with in the next few weeks i will be doing so much over due repairs/maintanence on the ol dakota.
heres the list
front and rear diff fluid switch to amsiol
ssbc turbo slotted rotors and pads for the front brakes
bleed brakes and same time of course
anything i need to know or anything else i should do while im at it, i bought it used with 137k so i have no idea when these things were last done. ive been searching around so i thought id ask for some pointers.
thanks
joe
heres the list
thanks
joe
Since yours is 4WD, you may want to change the transfer case fluid (it gets ATF+4).
Maybe also drop the transmission pan and change the fluid and filters. (unless, of course, its a manual transmission, than just change the fluid).
Oh, and grease any greaseable fittings you might find (u-joints, tie-rods, ball joints... sometimes there are greaseable ones on these trucks).
when buying a used vehicle the best thing you can do is assume that zero maitenance has been done to it. heres what i did to my truck when i bought it with 50k miles on it
Tune Up
Spark plugs (i went iridium)
cap and rotor
plug wires
air filter (i did a CAI but at least check your filter)
inspect and/or replace fan belt
Fluids
flushed cooling system
flushed tranny fluid
greased everything with a fitting
new thermostat
check rear differential
Inspections
check wheel bearings
check battery and terminals as well as engine ground strap
Other
drop in some fuel injection cleaner with a full tank of teir 1 gas (cheveron or 76)
car wash!
after all that you can resume the scheduled maitenance as dictated in the manual, your truck will be as new as a used truck gets. my total cost was around $250 and worth every penny
Tune Up
cap and rotor
plug wires
Fluids
new thermostat
Inspections
Other
car wash!
