running rich
Old Jan 3, 2007 | 07:47 PM
mroyal87's Avatar
mroyal87
Default running rich
I recently came to the conclusion that my 2000 3.9 is running rich. I smelled some gas in my barn today so I checked my exhaust and there was black soot[:'(]. I dont really have any experience working with fuel injection or computerized vehicles so are there any suggestions other just a tune up?
Old Jan 3, 2007 | 08:16 PM
dodgedakota98luver's Avatar
dodgedakota98luver
Default RE: running rich
number of things Front O2 Sensor. plugs wires etc..... front o2 sensor will really screw you up though if its bad. it may not nessesarily kick the check engine light to be bad.
Old Jan 3, 2007 | 08:33 PM
Chris's Avatar
Chris
Check your air filter, and consider moving to an air filter that allows more flow, i.e. a K&N. Also, check to make sure that your gas tank/lines/filler are not leaking.
Old Jan 3, 2007 | 09:09 PM
mroyal87's Avatar
mroyal87
I was beginning to consider my o2 sensor. Thanks for the info.
Old Jan 3, 2007 | 09:19 PM
mroyal87's Avatar
mroyal87
Is there a way to find out if it is bad?
Old Jan 4, 2007 | 12:40 AM
dodgedakota98luver
pull it out and see if it is really dirty sometimes you can spray them with some electrical cleaner and it helps but usually you just need to replace them. the only other way to tell if its bad is to have your truck put on a computer
