passenger airbag removal? need some help please
First of all, why would you want to remove the airbag?
Anyways... before touching anything, disconnect the battery negative cable, and wait at least2 minutes for the airbag system capacitor to deplete.
Than, you need to remove the glove box, as well as the radio.
You will need to reach through the radio openingfor most of everything. There are 4 screws to remove.
The airbag cover is held in place with 5 snap features.
The actual airbag module and the door are supposed to be removed as a unit.
