Subs in a regular cab
Old Jan 12, 2007 | 05:48 PM
Chris's Avatar
Chris
Default RE: Subs in a regular cab
I had to completely rewire the head unit I had installed at a best buy. [:@]
Old Jan 12, 2007 | 05:53 PM
CB's Avatar
CB
That's why I buy on ebay and wire everything in myself. I'm an electrician by trade so it's no biggy.
Old Jan 12, 2007 | 07:49 PM
User's Avatar
User
Best Buy that i work at is pretty good. These ones your talking about sound like f-ing retards.. If you can wire a harness then you def dont need to be in car audio at all.. all it requires to do a harness is to not be color blind.. how hard is that.
I do all my own installs, and some on the side, including the ones at best buy.
I did a job for some kid that came in and said he only had so much to spend, so instead of having BB do it i did it myself and made about 80 bucks.. so it wasnt that bad. SC Chev 1500 2x 10type e and a 600wat amp.
Old Jan 12, 2007 | 10:29 PM
RP Racing940's Avatar
RP Racing940
ORIGINAL: CB
Thanks guys. I'm still looking for a truck... I need something to haul my raptor around with. If you guys happen to find any nice ones hangin around northern Illinois let me know. I found a few on autotrader that I'm going to check out. The only problem is, I need to wait for my tax return to show up.
Try around Rockford/Belvedere area. With the DC plant in Belvedere, theres usually a ton if used dakotas. Just avoid Speedway Auto Mall. Waaaayyyyy overpriced.
Old Jan 12, 2007 | 11:22 PM
CB's Avatar
CB
I actually live in Rockford. There are a ton of Daks but I'm dead set on a manual tranny which are few and far between.
Old Jan 13, 2007 | 01:15 AM
cleverusername's Avatar
cleverusername
i fit 2 8" kicker cvr dual 4ohm voice coil in a custom box. they are pushed by a lanzar 800W max 2ch (briged) amp. i used 5/8 plywood and even made the cuts for the vents in the back. it works great because it allows for air flow around the amp. couldn't have worked out better. the box is bolted to the cab using stock bolt mounts. the 8's are great, they actually sound like 10's.
i wish i could have put 10's in there just because they are 10's but being 6'2" i need my leg space. i suppose if your leg space isn't an issue you could fit 'em there with no problem.
Old Jan 13, 2007 | 01:28 AM
cleverusername
here they are
[IMG]local://upfiles/39571/2E15062DA2284F6AA8BACCFDA85339C2.jpg[/IMG]
[IMG]local://upfiles/39571/2E50CA197A1D4F83A7BADDAC541F1562.jpg[/IMG]
[IMG]local://upfiles/39571/DC15A12D66D744A4B4174AB9436222E6.jpg[/IMG]
[IMG]local://upfiles/39571/1F3D1FAB9D4844FCB01153B7DDCC81A8.jpg[/IMG]
Old Jan 13, 2007 | 02:33 AM
RP Racing940
ORIGINAL: CB
I'm just up the I from ya across the border. I got my dakota in Fort Atkinson at teh Ford dealer. Have ya tried looking around Madison, Beloit, Janesville? Number of dealers up there to browse.
Old Jan 13, 2007 | 11:32 AM
lodakota99's Avatar
lodakota99
I fit an MTX amp... cant remember the series, under my pass. seat and I got a Kicker Solobaric 12' to fit. Takes up a lot of leg room, but itsounds good.
Old Jan 17, 2007 | 12:28 PM
Erich_121's Avatar
Erich_121
[quote]ORIGINAL: User2006
in a SC? How the hell did you get that 10 to fit in a truck box? Cut out the back? Let me know, becuase i cant fit 10 rs in the truck boxes i have but if i can then ill do that... lol.
[quote/]
I just made my own small box. It's got about .6-.8 cubic feet of air. I put it behind the passengers seat. There was a jack holder there but i took a hammar and smashed it down. lol.
