Foglights Inop
Old Jan 23, 2007 | 10:04 PM
michaelcat420's Avatar
michaelcat420
Default Foglights Inop
I was driving tonight and when i switched my foglams on I realized that neither of them worked. I looked at my fuse box and there is not a fuse designated for the foglamps. Any ideas as to what might be the problem?
Old Jan 23, 2007 | 10:09 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Foglights Inop
theres a relay under the hood for the fog lights, I would check that.
Old Jan 24, 2007 | 04:24 AM
RP Racing940's Avatar
RP Racing940
ORIGINAL: jonnymagnum
And theres more fuses there also.
Old Jan 24, 2007 | 12:27 PM
Erich_121's Avatar
Erich_121
The chances of a relay blowing is very small. More then likely you blew a fuse, and there is a fuse for the fog lights. If the fuse is good check all your connections. If thats good check the bulbs.
Old Jan 24, 2007 | 07:39 PM
RP Racing940
ORIGINAL: Erich_121
Wanna bet? Had relays go bad about as much as fuses.
Old Jan 24, 2007 | 07:44 PM
jonnymagnum
ORIGINAL: RP Racing940
ORIGINAL: Erich_121
same here. I went through 3 of them this summer[:@]
