Need some help....$$$
Old Jan 25, 2007 | 02:00 AM
01DakSport4x4's Avatar
01DakSport4x4
Default Need some help....$$$
Alright well in about two weeks im going to have about $800 to blow,so what should i do performance wise to my truck?
01 V8 4.7L, AT ,K&N CAI ,and magnaflow exhaust
Old Jan 25, 2007 | 03:34 AM
User's Avatar
User
Default RE: Need some help....$$$
I would go Headers....
Old Jan 25, 2007 | 10:25 AM
imnothot02's Avatar
imnothot02
gota love tax return time, imagine if everybody saved, instead of leting the goverment use your money for a year then giving it back....
Old Jan 25, 2007 | 12:31 PM
Twiztid's Avatar
Twiztid
I would do a throttlebody and roller rocker upgrade, and if you can do the work your self and look around for deals you might still squeeze some headers in there for 800.
Old Jan 25, 2007 | 01:41 PM
Erich_121's Avatar
Erich_121
Go with some performance rocker arms, gives you more lift for the valves. pretty easy to install too, just take out the old ones and bolt up the new ones. Get some new push rods too while your at it. Then if you dont already have an exaust or air intake get that, if you do then headers. An easy thing you can do is set your timing 4 degrees ahead for some more low end power. You can do that for free.
Old Jan 25, 2007 | 01:58 PM
Chris's Avatar
Chris
I say you blow it on some hot strippers.
Old Jan 25, 2007 | 02:02 PM
steve05ram360's Avatar
steve05ram360
I say save it... you never know when it might come in handy...
but if you must... your sig says it all... TB & headers...
Old Jan 25, 2007 | 02:32 PM
olsarge's Avatar
olsarge
Interesting! In the past I've always heard that the 4.7 didn't benefit from headers as there wasn't that much more flow over the stock manifold. And roller rockers on that engine?
2001 4.7 4X4 ATAFE CAI HO cams Aeroturbine muffler 4.56 gears Superchips Fastman T..B.
Old Jan 25, 2007 | 02:38 PM
steve05ram360
stock manifolds are made for the mass production lines... they wont flow as well as a set of headers. one thing that differs (at least on the magnum engines anyway) is that the exhaust manifolds have a common exhaust route. headers have separate exhaust tubes for each cylinder which makes it more efficent.
Old Jan 25, 2007 | 02:43 PM
olsarge's Avatar
olsarge
Agreed in general. but with the Dak. there is supposedly not enough room to improve the flow. And "supposedly" it is only at higher RPM's and will rob some lowend torque. I'd really like to know from sure from someone who has done it.
