timing chain rattle?? 97 3.9?
Old Jan 19, 2007 | 12:25 PM
Erich_121's Avatar
Erich_121
Default timing chain rattle?? 97 3.9?
I've been doing some research and i think the rattle my truck is making could be the timing chain. I guess the 3.9 doesnt come with a tensioner? am i right on that? Should i just buy a new timing chain and replace it or do i need to buy other things?
Old Jan 20, 2007 | 07:42 PM
Erich_121's Avatar
Erich_121
Default RE: timing chain rattle?? 97 3.9?
anyone?
Old Jan 20, 2007 | 08:06 PM
dodgerules86's Avatar
dodgerules86
Yes, apparently, the 3.9L motor didn't come with a timing chain tensioner from the factory.
Read this TSB.
Old Jan 22, 2007 | 11:27 AM
Erich_121's Avatar
Erich_121
So should i just buy another timing chain and forget about the tensioner? Its 41 bucks for that thing. I would think that if i put another one on the slack would be gone and so would the noise.
Old Jan 22, 2007 | 03:35 PM
steve05ram360's Avatar
steve05ram360
do a good double roller chain and you'll be good to go. the tensioner is for a stock chain and not necessary IMO for a good double roller setup.
Old Jan 22, 2007 | 03:37 PM
Erich_121's Avatar
Erich_121
ok ill do that. My next question is how do i get the damper and balencer off? im stumped on what tools i will need. Any ideas?
Old Jan 22, 2007 | 03:39 PM
Erich_121's Avatar
Erich_121
My understanding was that i need 2 tools. One to pull teh damper, and one to pull the balencer, is this right?
Old Jan 22, 2007 | 03:53 PM
steve05ram360
no the dampner & balancer are the same part, just different terms for it. your biggest headache is going to be getting the crank bolt loose. if you have an impact wrench, use it. it's your best bet. if not, a good strap wrench would be your next best bet.
Old Jan 22, 2007 | 04:11 PM
Erich_121's Avatar
Erich_121
ok, i know im asking the question on 2 different threads, sorry about that. Its just so damn confusing. Im trying to get the right tools before i tackle this job.
Old Jan 23, 2007 | 03:24 AM
dave2003's Avatar
dave2003
Check out the write up on the following site for Timing chain repplacement.
http://www.pavementsucks.com/tech/timingchain.php?p=1
