O2 OE or Aftermarket
What have people done,I can get aftermarket for 30 bucks OE are about 70-80...
http://cgi.ebay.com/OXYGEN-SENSOR-do...QQcmdZViewItemi dont kkow how to tell what is a good sensor...
Problems with not using the factory plug?
Yea, I have heard the universal ones aren't good.
Also, like horatio said, I would stay away from having to cut or splice into the OEM wiring. The oxygen sensors produce very low voltage (0 to 1 volt, depending on oxygen content, of course), so keeping as little resistance as possible in the wiring is key (especially since the lower the voltage reading the PCM gets, it thinks it needs to add more gas).
how do you replace an O2 sensor? I assume it is a DIY project, but some pointers would be good.
