tires
Old Feb 3, 2007 | 07:29 PM
hotmilkman's Avatar
hotmilkman
Default tires
I have a 99 dakota sport 4x4, I have a 3" lift on it and want to up grade the tires. Right now I have 31x10x15, I want to get 33x12x15. Will this fit?
Old Feb 3, 2007 | 08:36 PM
imnothot02's Avatar
imnothot02
Default RE: tires
no clue, what kinda rims... on factory no... some with a larger offset yes
Old Feb 11, 2007 | 06:59 PM
hotmilkman's Avatar
hotmilkman
Default RE: tires
So what's the biggest tire that will fit on the sock 15" dakota rims?
Old Feb 11, 2007 | 07:15 PM
DakotaMan's Avatar
DakotaMan
Default RE: tires
This question comes up all the time 32x11.5 should fit on stock but may rub a bit may have to cut the plastic out...Yea what imnothot02 said you will need some offset rims for the 33's but would still rub probably.
Old Feb 12, 2007 | 08:41 AM
hotmilkman's Avatar
hotmilkman
Default RE: tires
Will it rub all the time or only when making sharp turns? With the 32x11.5.
Old Feb 12, 2007 | 10:20 AM
imnothot02's Avatar
imnothot02
Default RE: tires
TURNS...
Old Feb 12, 2007 | 11:37 AM
Erich_121's Avatar
Erich_121
Default RE: tires
i dont think you should put bigger tires then 31x10.5s on the stock dakota 15" rims.
Old Feb 12, 2007 | 01:12 PM
hotmilkman's Avatar
hotmilkman
Default RE: tires
Why not put bigger tires on stock rims?
Old Feb 12, 2007 | 01:51 PM
Chris's Avatar
Chris
Default RE: tires
Because they do not have the correct offset. When ever you turn, you will be hitting the frame. Do a search on this topic and you will find everything you need to know about it.
