no heat while idling
Old Feb 4, 2007 | 03:42 PM
Barry J's Avatar
Barry J
Default no heat while idling
Been having a lot of troubles with my 2002 Dakota 4.7 4X4. I started having no heat on idle and plently of heat while driving.
Seems to be sporatic right now.
While cold I opened the radiator cap on the top rad. hose. There was no coolant at all in the hose. (my idea was to burp the system of air) I ran the truck for awhile to see if the coolant would could up to the hose...it didn't.
So i put the rad. cap back on, and drove the truck for awhile to get the circulation going. Then checked the reservoir...which all my coolant level holes had coolant in them (on the stick). So, I believe the reservoir is up to it's required level.
After this I let it cool, then opened the rad. cap again and still no coolant in top hose. Shouldn't I hav e coolant in the hose??
Is it not sucking from the resevoir?
Any suggestions?
Thanks
Barry
Old Feb 4, 2007 | 05:25 PM
imnothot02's Avatar
imnothot02
Default RE: no heat while idling
how hot is your truck runing...could be a water pump that would be my guess
Old Feb 4, 2007 | 05:27 PM
imnothot02's Avatar
imnothot02
oh nad no it wont suck if it isnt full to begin with fill the radiator...
Old Feb 4, 2007 | 05:39 PM
Barry J's Avatar
Barry J
So what right now, it has not been running for 3 hours, I should be able to go out there now and open the rad. cap on the top hose and there should be coolant in that hose correct??
That being true, if the rad. cap is in place and I run it the coolant should be sucked out of the resevoir and into the radiator, right??
Then why isn't any coolant in the hose at the end
Barry
Old Feb 4, 2007 | 06:26 PM
imnothot02's Avatar
imnothot02
if I'm understanding what your asking you have to have the system full in the first place to siphon out of the resevwar... it sounds like your system isn't full to me...ever siphon say gas...same philosophy
Old Feb 4, 2007 | 06:35 PM
Barry J's Avatar
Barry J
Ok, so right now I go out to my truck which has been sitting for about 4 hours now, I pop the rad. cap on the upper hose, and keep filling that until it's to the top of the filler neck??
Old Feb 4, 2007 | 06:57 PM
imnothot02's Avatar
imnothot02
uhm yes...mix it 50/50
Old Feb 4, 2007 | 06:58 PM
imnothot02's Avatar
imnothot02
idk how you havnt overheated your truck by now...
Old Feb 4, 2007 | 07:00 PM
Barry J's Avatar
Barry J
Why would my mechanic think there was too much coolant in the reservoir?? I won't be filling it up too much if I fill thru the rad. cap, when the reservoir is full??
Thanks
Old Feb 4, 2007 | 07:01 PM
jonnymagnum's Avatar
jonnymagnum
yes, fill up your rad to the very top with a 50/50 mix of coolant and distiled water. I would never put tap water in your engine.
