Cruise Control Problem
Old Feb 7, 2007 | 06:00 PM
carisu's Avatar
carisu
Default Cruise Control Problem
I've had problems with my cruise control getting stuck on with the throttle wide open. It happens because with a manual transmission, when the trottle opens up to try and get me back up to speed when it's pulling a little harder it gets stuck in that wide open position. Even when I tap on the break or disengage the clutch it doesn't let go of the throttle. When i disengage the clutch, the engine just wants to run away. I've had to just disconnect the crusie control from the throttle for now. Does anyone have any suggestions?
