tapping
Old Feb 11, 2007 | 04:52 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Default tapping
well my engine has been knocking/tapping for awhile now but i noticed if i let it sit and idle for about 30 seconds after starting the tapping mostly goes away but if i tap the gas when its out of gear it will knock really hardbut if i'm hot roding and then stop it doesnt knock and my oil pressure gauge reads around 60 or so then as it sits there and idles it slowly drops down to about 40 and it startsknockingagain? any ideas? bottom end problems? oil pump? pluged upsomething or other? what do you guys think?
Old Feb 11, 2007 | 12:16 PM
01dodgedriver's Avatar
01dodgedriver
Default RE: tapping
Sounds like a lifter tick... How cold is it where you live? and what grade oil do you use?
Old Feb 11, 2007 | 09:01 PM
imnothot02's Avatar
imnothot02
Default RE: tapping
ORIGINAL: 01dodgedriver
that or mabie even a bad pcv valve..
Old Feb 11, 2007 | 11:20 PM
98Dodger4x4's Avatar
98Dodger4x4
Default RE: tapping
Use some lucas and change the oil I bet it stops
Old Feb 11, 2007 | 11:21 PM
01dodgedriver
Default RE: tapping
ORIGINAL: 98Dodger4x4
I second that
Old Feb 12, 2007 | 12:15 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: tapping
I third that
Old Feb 12, 2007 | 12:59 AM
dodgedakota98luver
Default RE: tapping
i've got some lucas just havent put it in yet. and its been about -3 Farenheit with a windchill of -15 this past week or so.im noticing an antifreeze smell when i start it now exhaust smells funny too
Old Feb 12, 2007 | 10:28 AM
imnothot02's Avatar
imnothot02
Default RE: tapping
that cant be good...
Old Feb 12, 2007 | 11:36 AM
Erich_121's Avatar
Erich_121
Default RE: tapping
You know what that means right? You have a leaking headgasket.
Old Feb 13, 2007 | 01:49 AM
dodgedakota98luver
Default RE: tapping
yeah thats what i figured. i'm betting on a bent rod making the knocking sound.
