Key won't turn
Old Feb 16, 2007 | 12:51 PM
suthie80's Avatar
suthie80
Default Key won't turn
Anyone else have this problem ? I went out the start my truck this morning , put the key in the ignition and it wouldn't turn at all. I tried cranking on the steering wheel, hitting the shift lever but nothing worked. So I went inside and opened up google and luckly I found a forum out there that discussed this exact problem. Appartently it's a common problem with Chrysler products. So I read on the formum that if you hit the key with a mallet while its in the ignition it will work. So I gave it a try and IT WORKED !!!!!
Has anyone else had this problem ? I'm guessing that I will eventually have to replace the ignition but hopefully not right away.
Take it easy .
Old Feb 16, 2007 | 01:51 PM
Chris's Avatar
Chris
Default RE: Key won't turn
Be careful while doing this, not only will you most likely damage the ignintion, but the key as well. Try applying the brake while turning the wheel. I know you said you already did, also make sure the shifter is in park or neutral.
Old Feb 16, 2007 | 02:15 PM
suthie80's Avatar
suthie80
Yeah I tried that a whole bunch of times and it didn't work. Any other suggestions that might be less risky ? Has anyone replaced an ignition cylinder before , how complicated is it ?
Thanks
Old Feb 16, 2007 | 04:17 PM
imnothot02's Avatar
imnothot02
Im sure this isnt the problem, but ive had problems with other vehicles that the key gets worn over time and then dosnt work properly...
Old Feb 16, 2007 | 08:51 PM
titan2087's Avatar
titan2087
Iv had that happen to me before but after about 10 minutes of messing with the steering wheel jiggling the key and such it turned never had the problem again... But ya iv had that exact problem on my company truck aswell lol where the key was so worn out youd have to spend 5 minutes on it trying to get it to turn unless you new how to turn it just right lol it was so worn i could pull the key out of the igniton while it was running with littel effort.. but after i got a new key made it was fine
Old Feb 16, 2007 | 08:54 PM
Billiam's Avatar
Billiam
Get a new key. I had a problem with a older car before, it wore out. So I went out and got a new key and it worked.
